Sorry, another Radiator removal question on a combi system
13 Sep 2007
I know it's a subject that's been covered a lot (and I've read all the FAQs) but some of the previous posts seem to conflict and/or don't match my boilder setup, so I'd really appreciate it if you could give me some pointers on how to remove a rad for decorating then put it back without blowing my house up!.
As I understand it I need to do the following:
TO REMOVE RAD (Without Draining Whole System):
- Close both valves on ALL rads (Is this excessive?)
- Close all valves under my Gloworm Combi-boilder(inc Gas?)
- Turn off boiler
- Remove and drain target rad (which will depressurize the system)
- Bleed all other rads before system startup (top floor down)
- Open valves under boiler
- Turn on boiler
- Top-up using filler loop (under boiler)
- Open all other rad valves (bottom floor up)
TO REPLACE RAD AFTER DECORATING
- Repeat all of the above
Does that sound about right or am I a danger to me and my neighbours?
Many thanks.
only rad your disconnecting
no
yes
then when refitting check boiler pressure is about 1.5 bar refit rad open valves, top up pressure to 1.5 bar, bleed rad, check pressure is still ok, fire up boiler
you can still use boiler with that rad disconnected providing your pressure is ok.
Thanks for the quick reply, so just to double check I don't touch any of the valves directly under the boilder itself, just shut it off?
Cheers,
Doug
yes just make sure the boiler don't call for heating or you'll be working with hot pipes and water.
once rad valves shut off ok to use boiler cause the water in rad will stay cold.
just check your valves shut fully when rad removed or they will keep dripping and your pressure will be lost.
