In need of a bit of advice. I have a bedroom above a kitchen and from the bedroom you can hear everything in the kitchen - every little sound. This is because there are gaps between the bedroom floorboards and a very thin foam-backed carpet with no underlay. Sound insulation is non-existant.
So, I know I can improve the sound insulation a bit by just fitting a decent underlay and carpet, but is that likely to be enough? Would laying hardboard help significantly too? Or should I go to the effort of taking up the floorboards (which also means removing the skirting boards by the look of it...eugh) and fitting some rockwool-type insulation?
