i was cutting the grass other day and hit a bit of metal in garden with petrol mower the engine stopped and oil came out of air filter any ideas wot it could be
Did you turn machine over onto its side - the air filterside? If so then the engine oil has ran from the crankcase into the air filter via the crankcase breather. Buy a new air filter (paper 'cartridge') and fit that.
Take the plug out before you try to start the engine and pull the cord a few times to make sure you do not get a 'Hydraulic Lock'.
If it came out of the air filter without laying the machine over then I guess it's FUBBed...
