First off, I must point out that I will NOT be doing any gaswork myself! Seeing as I don't always make water joints seal first time, there is no way I am touching gas. I have highlighted gas-fitter just to emphasise this!
I am fitting a new kitchen. I will be getting a CORGI gas-fitter to plumb in my gas hob. However, I have uncovered what could be an expensive problem: currently there is a cooker bayonet socket elbow coming straight out of the wall. This will obviously be replaced with a micropoint socket for the solid piping that the gas-fitter will fit. It would appear to be screwed into a 1/2" BSP outlet. But here comes the problem:
The built-under oven will be installed where the bayonet socket currently comes out of the wall. I need 55cm depth for the oven (not including any clearances). But, the depth of the cabinets means that the rear of the oven will only be 2-2.5cm from the wall.
Will 2cm be enough space for a 90-degree elbow for micropoint pipe?
