Thought I'd run this one past you knowledgable lot...
A client that I do website and database stuff for asked me a question about his wiring that I didn't know the answer to.
He has extended an existing dimmer switch with a simple 2 core and earth to relocate the dimmer. All is wired correctly and works as it should. However, when connecting the earth from the extension cable to the original back box he noticed that he gets a tiny spark and was asking why.
I don't have my meter to test anything.
It is standard loop in wiring as far as I can tell, and the extension cable doesn't run near any others (my first thought was possible induction voltage).
It is a tiny spark, but it is there and repeatable, so clearly there is a small current. Is the dimmer switch (Brass effect Volex) likely to be introducing this as there is nothing else I can see that could cause it?
Gavin
Gavin
