Special tool for square radiator valve tails
23 Mar 2013
Essex
Hi there,
I realise a decent adjustable spanner will usually work, but I wondered whether anyone knows if there is a tool specifically designed for the square section radiator valve tails that are now so popular.
Today I removed some old internal-hex-type valve tails using a radiator valve allen key (and a 2ft tommy bar) and wondered what I will do when I have to deal with a square tail that is stuck this hard.
Surely I can't be the only one who wants a proper tool for this?
R
Decent spanner and if it's stuck just get the blow-lamp out and give it some heat! No other way really.
Not all of them will be the same size from different manufacturers so it would be difficult to make a universal tool!
As someone said on another forum then, plumbers have to make the best of the worst materials :roll:
Well, thank you, at least I know I'm not just being ignorant in not having a specific tool.
Came across my old thread LOL. Just to update, Monument has come out with what it calls a TRV Tail Driver. I doubt it would fit a very long tail, but seems to fit standard tails and work well.
It's not 1/2" though. Welcome to plumbing measurements!
It's usually 1/2" BSP thread on a rad tail and the stated size is the nominal bore of a steel pipe of a certain wall thickness. So the flats on the 'square' tail are approximately 0.600" AF. Also they are not deep so the chamfered head of a socket driver wouldn't have much purchase (but might have been worth a try if it were the correct size).
Kind regards,
R
I bought one of those a couple of years ago. I have never ever used it.
On new radiators, That Rapid Blue Stuff and your hands are fine for making the tails in.
If you're trying to take old tails out, the adapter is useless because there's a compression nut and olive in the way.
