Speedfit vs Copper - flow
16 Feb 2005
I've never used plastic pipes for plumbing before, but i'm just about to redo the whole bathroom so i bought some 15mm speedfit pipes and connectors.
After trying them to test the connections i noticed after inserting the pipe inserts into the plastic pipe the actual pipe diameter is now nearly half that of a copper pipe.
Surely this will affect the flow rate to the shower, bath and taps?
I'm tempted to use normal 15mm copper to ensure a decent flow rate.
What do you think? Will i see a difference?
Thanks a lot.
if your water supply to bath/shower etc are gravity then yes it will restrict.
cold is mains pressure and hot is direct from valliant combi.
So even though the speedfit's internal diameter at joints/connections is a lot smaller than 15mm copper it will have the same performance?
