spindle spacer fillets
18 Feb 2006
Birmingham
Im replacing al the spindles and only have fillets with my base rail so need some for my hand rail.
is there anywhere I can buy just these?
table saw bit off 2x1 par[planed]
2 passes over the table [thickness then width] :D
you can only buy long lengths to match the handrail or string cap your buying or trying to match
you can't buy individual lengths because the angle of cut and length is different for every set up hence the suggestion of running up your own at 2 passes per length much much easier [if you have a saw ]than trying to source the correct profile off the shelve or cut by someone else
