Split DC Inverter Type Air Conditioner
2 Feb 2016
Not sure if I am on the correct thread as I couldn't find anything specific to A/C systems.
I have a Blaupunkt Split DC Inverter Type Air Conditioner. It has the outdoor unit and indoor unit. It was installed about 8 years ago and has been running good since. Recently, i keep getting error E1 showing on the display. Sometimes it starts and blows air a little bit then goes to E1. Yesterday it randomly worked for a few hours but now it's back to the E1.
I checked the outdoor unit and opened the sides and cleaned the electricals area but this hasn't helped. I noticed that when I turned the indoor unit on, usually the outdoor unit's fan would spin but now its not turning the outdoor units fan on at all. Like the indoor unit can be blowing air but outdoor unit not doing anything. Then it goes to E1.
I've attached a pictured diagram that i found on the cover of the outdoor unit which seems to be a system diagram. Can anyone kindly advise, what could be wrong?
Thank you
E1 suggests it's a common error; a likely cause is loss of refrigerant pressure - you'll need a suitably qualified engineer to top it up. In any case messing with aircon is not really a diyjob and can be hazardous.
