Hi there,
I have a split spindle offset lever/pad multilock door mechanism on my upvc front door. When i close the door from the inside i need to lift the handle to engage the latch and multilock, the trouble is that people can still open the door from the outside.
I normally have to use the key to lock from the inside whiich is annoying.
My question is, what do i need to do change it so that I can just close the door from the inside by lifting the handle and this then stops anyone from entering from the outside without a key. When i leave the house in the morning I will need to lift the handle to engage the latch and multilock, but then be unable to open the door again unless I have a key.
Is this possible?
thanks
Is this possible?
thanks
