Installing some electric underfloor heating in 2 rooms, both will total approx 3kw each (20m² with 150w/m² mats), each on a 16a thermostat with 2.5mm² running to CU on 16a breaker each.
However as there is limited space available in CU can they be connected to a single 32a breaker, then using 4mm² out to a junction box which then splits to 2.5mm² to each thermostat?
Cables will be clipped direct to surface in loft (roof timbers & raised off insulation), dropped down into room and buried in wall surface in suitable conduit. Heating in each room may be in use at same time.
Thanks very much,
Thanks very much,
