Can you spot it?
Like all the browns going into the neutral bar and all the blues into the MCBs, you mean?Can you spot it?
Isn't that enuf?Keep looking![]()
Would it really be all that much work to get it at least 'safe'. Swapping all the blues and browns, sheathing the CPCs and tidying up the terminations would not take very long, nor, I imagine would getting a proper earth feed (from the SWA armour - is that what RF meant - or elsewhere).RF, what did you do about it? If the customer doesn't want every thing sorted out (which by the sounds of it could be a lot of work) what can you do!? Apart from refuse to do anything at all and just leave!![]()
Ah, I seeJohn, every joint and accessory throughout this part of the building is in a similar state to the CU.
