Yes.Any way around cutting big holes in the insulation?.
Do not use lights which need holes cut in the insulation.
Is that what the manufacturer's instructions state?I was thinking more like LED spotlights perhaps?
The holes in the insulation wouldn't need to be larger than the spotlight
But still HOT.because they run a lot cooler.
Still holes though, aren't they.The holes in the insulation wouldnt need to be larger than the spotlight because they run alot cooler.
Or you could use lights designed to light up room spaces, rather than ones designed to not do that.
But that is precisely the problem, which you keep on admitting.A single spot isn't designed to light a room, but that's not what we are talking about. Several spots ARE desinged to light a room, and do so very well.
No they do not - if they did work well at lighting up rooms you wouldn't need lots of themIn THIS instance they are not the correct light, in many other situations they work very well.
It makes it designed to not be fit for the purpose of general room illumination.Just because you need to have more than one doesn't make it a poorly designed light.
They would be badly designed as lights for general room illumination if you needed 25 to light a lounge and kitchen.Are multi-lamp chandeliers badly designed?
