I know that normally the ends of floorboards need to be supported. However, if the ends are T&G'd do they need to be supported by a joist, or can the join sit between joists?
OK, I'm a bit confused - the short ends are T&G'd, so going back to the original question... Better if on joists, but what if the join isn't above a joist? Do I cut a new end so it is over a joist (but no T&G) OR go with the flow and just assume that the T&G will help to support the board over the gap (22mm thick oak board).
Dave, if you quote you have to quote the whole context:
Oak floorboards of 21mm thick without T&G can be face-nailed on top of the joists (but note maximum space between joists), as long as every board rests on at least three joists. Because the short sides of the boards don’t have connecting T&G’s for stability between the boards it’s recommended to end every board on a joist.
Thanks for the info. I tried to cut down the quote to the pertinent bits only. Hence, just referring to the bit about ends only. However, the result is the same . So, I'll now start work and not worry about joists.
