Spray on grease
Yes, that's the stuff.....make sure you treat the door check straps at the same time!
Its also good for the bonnet catches.
John :)
rather than spray around, you can also apply it with a small paintbrush.
The same paintbrush is useful for cleaning those areas, and around the hinges. I just use car shampoo on the rare occasions I clean it thoroughly.
If you are applying something like WD40 with a brush, you squirt it into the bottom of a jamjar or similar, then roll the brush around in it.
At the end of the day, its debatable if any lube actually gets where its needed.....however, a spray of the white grease indicates to the punter that maximum care has been taken when the car is in for service ;)
John :)
Love the stuff. I use it on the handbrake adjusters on my sprinters as they are crap and seize up without it.
