Spraying Skirting board
apl
11 Oct 2008
Liverpool
Hi had some pre painted wooden skirts fitted which had been nailed in also the colour is more of an off white so I’m going to fill the nail holes & as I’m doing the house up I’ve bought a Wagner 150 paint sprayer & was thinking of spraying them. What’s the best paint to use to get a good finish cheers.
16 Jun 2006
London
Waterbased eggshell should be fine. You are probably going to need to thin it with water first. Floetrol is also helpful, it helps the paint flow without actually thinning it. Not cheap but great stuff.
https://www.owatroldirect.co.uk/product/floetrol/
My experience of spraying is limited to HVLP rather than airless so I have no idea how much you will need to thin it. The manual may be able to advise you. Did they supply a cup with a little hole in it- A viscosity cup. You measure the time between drips to calculate the thickness of the paint.
  • Thanks
Reactions: apl
24 Oct 2020
You going to have to thin the paint to get it through the 150 is my understanding although not used one myself.
Best try first on some paper and get going.
  • Thanks
Reactions: apl
apl
11 Oct 2008
Liverpool
Hi thanks for all your answers as there really helpful & the machine didn’t come with a viscosity cup cheers
12 Jul 2004
Surrey
is it really the best option ??
if you have a empty room you will still get over spray and droplets every where so you will need to mask off whole massive areas to protect any now finished surface like flooring 'floor covering or wall covering ??
  • Thanks
Reactions: apl
