- Joined
- 18 Jan 2022
- Messages
- 1
- Reaction score
- 0
- Country
I’m planning on installing some electric underfloor heating under engineered wood.
I’m looking at a Warmup foil heater system. It’s for a small room (approx. 2.5 x 2.5m) already with a radiator, so the underfloor heating is additional to ensure the floor is not too cold. Warmup’s literature shows that a 5m^2 pad is rated at 700W, drawing some 3A.
I intend to spur off the ring main at a power socket, connecting the thermostat via a RCD protected FCU (Warmup used to have one, now maybe discontinued?). Is there any reason why this instead would need to be on a separate circuit run from the consumer unit?
I plan to site the FCU close to the existing power socket just above the floor, with power running chased into the wall up to thermostat at “light switch level”. Warmup advise cables are in conduit and that cable for the temperature probe is in a separate conduit. Is this separate conduit necessary?
Although I’d argue I’m competent I’m certainly not qualified, and I believe such work is notifiable. What elements of this work needs to be left to a qualified electrician? All connections? Do I leave filling in until after sign-off? Is it recommended to find an electrician before work begins and then again when ready (I’m conscious this is a small job for an electrician who may not be willing to travel for little gain)?
Any pointers gratefully received! Many thanks in advance,
Mike
Mike
