I've been asked to replace a fused spur, and on inspection the double socket the fuse spur is fed from only has a single incoming cable, this socket also feeds some other retrofitted double sockets. The mcb is 32 amps and has 2 cables feeding it. I've refused to change the fused spur, because without taking the decking up in the loft I have no idea how its wired.
The property is a bungalow and I have a suspicion that the ring is run in the loft and single cables are run down the walls from it (which logically seems fine unless, loads of extra sockets are added).
I've explained the problem (I'm actually doing some carpentry for the client and don't want to get involved), and suggested they get someone in to take a look, but I'm also tempted to suggest the following options as possibilities - running the extended sockets (to the next original socket thus remaking the ring), or changing the mcb's from 32s to 20. There isn't much equipment in the house, the washing machine, fridge, kettle, dishwasher e.t.c. are all fed either by a 20 amp kitchen circuit or a 20 amp garage/outhouse circuit.
Would it be acceptable to swap the mcb over to a 20, giving the cable extra protection and therefore not needing any immediate additional work?
The chap who did the work, an LEB guy, died a number of years ago, but was a family friend so the clients are sure he wouldn't have done anything dangerous.........
