Candle diffuser that spilt over was left on UPVC window frame which has stained it red from the oil. Tried removing with a UPVC cleaner and cif but no luck.
The dye will have soaked into the pvc, I suspect it will be there a long time, but try isopropyl alcohol, it might help. or some vaseline on a kitchen towel, if the dye was in the candle wax it will be an oil based dye and most likely soaked in.
