Stained stainless steel on dishwasher door
26 Sep 2009
London
I have a stainless dishwasher, but the bottom foot or so of the stainless outer door has become stained. What is the best way to clean it/ refinish it.
If cleaning fails to work, would it be possible to get it refinished if I took the outer door off.
It's a Miele product, so the cost of refinishing the door if needed would be worthwhile I think.
It just looks tatty at the moment.
20 Nov 2009
Aberdeen
There are several "off the shelf" stainless steel cleaners available, check out your local supermarket or google it.
A trick I sometimes use on tatty stainless fascias is to spray it lightly with WD40 then give it a good buff.
If none of the above work then you could always replace it. If you post the full model details we can direct you to spares/prices.
30 Apr 2008
Baby oil is also good on stainless steel.
14 Mar 2006
Kent
Cleaning Stainless Steel Appliances
Cleaning with vinegar makes it easier to remove streaks from stainless steel appliances. Apply vinegar with a soft cloth. Try in an inconspicuous place first.
From the vinegar institute , where else.
18 May 2007
I had a mark on my SS freezer door, I gave it a rub with T cut.... ( that stuff for cars). It got rid of the mark and I then gave it a once over with baby oil
26 Sep 2009
London
I had a quote for the door for over £200 +vat... a white one is £80!
Ill try the suggestions, many thanks
