Stairs still patchy
4 Apr 2017
Hi folks,
Please can someone explain how to sort out my patchy stairs. I sanded down then used zinsser peal stop. Then I used zinsser 123 (two coats water based) but it all looks patchy. Please could you suggest what paints I should use next? Zinnser bin for the undercoat? What should I use for the final coat please? Any paints names I should use would help me out.
Since no-one else has replied yet (I’m not a decorator!):
Yes, because you haven’t painted it yet. It looks looks it has been very well prepared for painting.
What finish do you want? I imagine any decent undercoat and top coat combination would be fine - but check the instructions for the last product you applied and see what it says about compatibility.
Hi, I wanted normal white stairs, was hoping someone would advise after using the prep paint
Matt is fine
I’ve used Dulux Quick Dry Satinwood, with the corresponding undercoat, for matt white woodwork. There are plenty of similar paints available.
But I’ve not tried to use it for something as fiddly as your job - mostly just skirtings. It may be that you would find a solvent-based paint easier to get good results with. Maybe a pro will be along soon with some advice.
