- Joined
- 4 Feb 2019
- Messages
- 6
- Reaction score
- 0
- Country
Hi all, hoping someone can point me in the right direction with a Stanley Brandon (oil, with digital display).
I’ve been having a few issues that seem to have escalated:
Has anyone seen this combination of symptoms before on a Stanley Brandon?
Does this sound like a PCB failure, or something else I should rule out first?
I’m leaning to main PCB Board being the issue, If it this how old is to replace by a old ish IT Hardware Engineer of 30 years
Any advice or things to check would be massively appreciated
- Initially, the heating was cycling on for about 3 minutes, then off for 3 minutes repeatedly
- During that time, the radiators were getting very hot very quickly
- Then I started getting Boiler Limit / Oven Limit warnings, followed by Error Code 04 (overheat)
- Now the system has got worse:
- It’s not firing at all (no heating or hot water)
- The clock/display is showing a strange/random time
- Controls seem a bit off
- Turning the system off and back on
- Resetting where possible
- Checking thermostat settings
- Boiler thermostat / sensor issue
- Circulation or heat dissipation problem
- Or possibly the main PCB / control board (especially due to the weird clock)
