Starmer postpones elections even further in Reform areas...
What a twist.
You've had it thrown back at you at every turn
You proved you didn't even know which your convex mirrors were.
EVERYBODY reading this knows you embarrassed yourself over your mirrors. You can twist and squirm as much as you want. But you embarrassed yourself badly.
You tried proving you knew about the MOT and failed
You spoke to a tester apparently, which EVERYBODY knows was an outright fabrication.
If you insist on keeping embarrassing yourself, keep going. I've proven to you, I will keep going
You are at the bottom of a deep hole. Carry on if you want
You have proven you are not a good MOT tester if you are one that is, that is in doubt.
Go on then
Where has that been proven ?
Or just more bs to twist away from your embarrassment
You have proven by not knowing about a smashed mirror on an MOT also you did not know what a blind spot is as well as which mirror is which. Doesn't add up to a decent tester to me,
Go on then prove me wrong
The 2 people that didn't know what blind spot mirrors are, is you and mbk. There's another thread full of pages of you 2 getting it wrong for you to go and check.
As for the MOT test part. Do not try and quote some rubbish off the net and claim it is part of the test requirements. There is only 1 acceptable source and I copied and pasted it in here for you to read.
Embarrassing yourself further by not even believing the official testing manual.
You really are an embarrassment to yourself.
Stick to cleaning bulbs
I will pop some pictures on tomorrow in our workshops and show you some MOT failure mirrors. Ours are real MOT testers that test LGV as well as our cars.
Please do.
Ask the testers to show you the manual too.
You will see it's exactly what I showed you
Why do you keep embarrassing yourself.
Hope you've got a big ladder. You will need it to get out of the holes you dig.
You really are unbelievable. Why do you fabricate so much bs ?
Go on then
Fail (Major Fault)
  • Obstructed View: Any crack, damage, or tinting that significantly blocks or distorts your view.
  • Missing Mirror: If an obligatory mirror (driver's side or interior) is gone.
  • Insecure/Loose: If the mirror housing wobbles or looks like it could fall off.
  • Sharp Edges: Dangerous shards of glass or casing.
  • Non-Working Electric: Broken electric folding or adjustment mechanisms
Fail (Major Fault)
Now
Can you tell us what an OBLIGATORY mirror is please ?
It's in the manual. I pasted it earlier
