I am looking for a replacement for this:
It is in a fitting (5ft) which is located in a room which stores (among other things) highly flammable liquids. There is ventilation to stop a build-up of explosive gases and these two fluorescent light fittings with a heavy duty sealed construction - the lamp is inside a clear tube and this ballast goes in a cylinder-shaped void accessible only when the fitting is disassembled.
For obvious reasons I don't want to use a ballast with a sparking choke. The only electronic starters I can find are too long. Max size it can take is diameter 81mm and 235mm long.
Alternatively anyone got a link to a suitable replacement fitting?
Thanks for any help in advance.
