State of my Lintels. Help!
18 Mar 2022
Please cam anyone offer some help on the following...
I'm in the process of buying a house and the survey came back with photos of some cracks in the plaster board (very dated decor) and a comment that the lintels could need replacing... Its a 1950 construction with concrete lintels.
From the outside the lintels look ok.
Any thoughts on how to inspect the lintels without taking the plaster board off or anyone had a similar comment in a survey?
Usually lintel problems show up as cracks near the top corners of windows and doors.
there may not even be any lintels
is it brickwork outside - can you see any dropped brickwork above windows
Would that be cracks on the inside near the edges of the windows I should look for?
From the outside I can clearly see the concrete lintel above the windows.
I'll take a closer look at the surrounding brick work but looked OK.
More of a generic wall construction question, is there likely to be an internal lintel as well as an external lintel?
Thanks for your message!
Why not post interior & exterior pics of the lintels in question?
Are bays involved?
Have you put a level to the undersides of the lintels?
Hi, thanks for the tip on the level. All looks level on the outside.
It's not bay window in this instance.
I've put a pic of the outside ground floor front window. I haven't got any of the inside yet.
Buy the house.
Cavity walls have internal & external lintelling.
There are cracks in the conc lintel but no signs of sagging or associated cracks in the surrounding brickwork.
FWIW: Why not post the survey pics of the interior "plasterboard cracks"?
These issues are very common and no big deal - if necessary, in your own good time, you could have the lintels of concern replaced. A simple remedial job.
Thanks for the pics but where are these cracks in relation to the earlier photos?
What/where is the papered wall - is it above any of the lintels?
The cracks are from the room above the lintel pictured earlier. The papered wall runs perpendicular to the window.
Hope that helps, I don't have loads of photos to hand and they're not great quality.
The points from your survey about lintels may need replacing and cracks on ceiling plasterboard are not connected - as Woody states.
I would be guessing it’s a semi detached property that originally had Crittall windows.
The wire cut bricks were common to that period
even if lintels do need replacing, it’s not a deal breaker - sure it’ll cost a bit, but it’s not a can of worms
LBC rustic fletton bricks crittall windows - ex council house c.1950s ?
Hi all, thank you very much for the input.
I do have another picture below from the report, with a crack on the wall but I would need to check where in the house it is.
If I was to get someone to look at the property would they be able to tell me much more than the survey without having to remove plasterboard etc?
I see concrete lintels are relatively cheap so I assume the work is the main component of the costs, do you have any ball park figures of how much it would cost to replace the lintels?
Much more than a person who inspects houses for a living and writes survey reports you mean? :rolleyes:
