Been asked to install an 8kW steam generator (still don't see the point of these but there you go.) and thrown in at the last minute is a mira body dryer also at 9kW.
Running another circuit is of course, a PITA, especially as the existing shower circuit which wont be used as the shower will be run off the combi and I plan to re-uuse for steam generator (tests, method of install all ok).
The mira body dryer can be wired so that when a shower is not in use the same circuit can be used to power the body dryer but I'm not sure how this works with a steam generator instead of a shower. Both will never be used at the same time so i'm thinking of going for a pull chord operated change-over switch.
Any thoughts sparks?
