Stepped retaining wall - footer dept / reinforcement
11 Nov 2024
I am planning on putting some footings in for a short retaining wall.
The ground is rock solid - I required a pecker on the digger to move the ground back a meter.
Working with the levels (house floor levels, subsequent decking etc) the footings would need to be 100mm to 150mm. Going any deeper on the footings would require significant effort pecking out a trench. It took a lot of effort bouncing around in a micro to get this far. Ground is very tough - 10 inches of soil and then its just rock all the way up the plot.
My question
- would a 100/150mm footing be adequate considering its being laid directly onto bedrock? Should I add in some fibres / or mesh to help with strength?
- The footer is currently 1200mm wide / 13m long (may be reduced as the wife has changed her mind slightly)
- The wall will be stepped - two rows of blocks roughly 1m tall and 500mm tall.
Before I put in a sizeable materials order I just want to sense check my approach is ok. Dont want to go through this effort & cost only for it to be a waste of time.
As an aside the last retaining wall lasted 60 years and was set on nothing more than a bed of mortar, so I suspect I will be fine. But I defer to more informed opinions.
Cheers
James
In my unqualified opinion, you can't get a better footing than that, there's absolutely no point in digging into it.
I'd jetwash it first though, blow the mud out and get a jagged rock base. As it stands, your concrete will only be about 25% in contact with the rock, the rest would have squidgy mud between the concrete and rock.
100 will be fine. It should be twice as wide as the wall - more for stability than bearing in this case.
Fibres are to control drying cracking in screeds not concrete, and do not give a mix any strength anyway. You don't need any mesh.
Drainage of the retained soil would be important.
Thanks for the responses guys! Appreciate it.
Drainage wise I have access to some free perforated drainage pipe - plan was to lay this down behind the wall (also have the suitable membrane available for free), then cover with some 20mm clean and then back fill with the extracted spoil (mostly stone and soil). I assume if I leave weep gaps at the bottom of the 2 walls that should be adequate for the wall to drain?
Another quick question - would 100mm blocks be ok for the retaining wall or should I use 215mm hollow blocks instead (up to a point and then finish with 100mm).
Cheers
Drainage plans sound fine to me. You can just pipe out to the surrounding soil to the sides instead of going through the wall if that's possible, avoid any holes.
Personally, I wouldn't use block at all. Use brick.
Painted or coloured rendered garden walls look great when new if you want that trendy look of the moment. In reality, a couple of years down the line it will all be cracked and green.
Painted or coloured render is fine on houses where there's a damp-proof course and it's heated. Retaining walls are utterly different, the damp gets trapped behind the paint and blows it off, or just makes it turn mossy.
100mm block will be OK.
Drop a sheet of DPM down the back of the wall to keep a lot of the damp out and prevent pattern staining
