I
iDIY
Hi Guys,
As Im preparing my site for a new extension I have removed an old prefab garage to reveal a retaining wall that has been built onto a stone glazed sewer pipe, resulting in the inevitable damage.
Obviously I am sorting this in the preparation of the site stage so as you can see in the picture, I have exposed the pipe, cut away the retaining wall and foundation and installed a lintel.
The next stage is to replace the broken pipe in a way that when I actually get to building control, it will be acceptable to the BCO.. The damaged pipe is about 188-190mm outside diameter with roughly 18mm thick walls making it about 150-152mm inside diameter.
Do I go for 200mm OD plastic pipe and straight flex seal couplings or 160mm OD plastic pipe with stepped flex seal couplings. Im assuming 160mm OD which has 152mm ID which is the same as the original pipe and results in no internal step?
