Hi all,
I wanted to install a multi fuel stove into an unlined chimney flue which has been tested by a chimney sweep to be sound. However, when I place the stove the recommended min clearance of 76mm from the backwall, the 5" pipe will be a matter of 5 or 6 centimetres from the inside of the front ewall of the chimney breast which is brick. From my understanding it would need to be at least 19.1cm from non combustible material. Does anyone have any suggestions of a way around this?
Many thanks in advance
