Strange blinking of light bulb after switching off
Been asked and answered many times
When the switch is OFF capacitive coupling between Live and Switched Live in the wiring to the switch allows enough energy to reach the lamp and make it flash. A well known problem with energy saving lamps. They save this very small trickle of energy until it is enough to make the lamp flash.
If this has suddenly started to happen then you should check that the earth conductor in the cable to the switch is still intact and connected to the earth conductors. With the earth in place the capacitive coupling Live to Switched Live is less effective.
Putting a capacitor across the lamp will absorb this energy and prevent the lamp flashing.
http://www.diynot.com/forums/viewtopic.php?p=1378727#1378727
Capacitor 0.047uF micro Farads 250 volts AC in series with a resistor 100 ohms
Which come pre-packaged as a contact suppressor from RS Components
RS Stock No. 206-7847
Manufacturer Evox-Rifa
Manufacturers Part No. PMR209MB5470M100
There are other sources of the contact suppressors
Read more: http://www.diynot.com/forums/viewtopic.php?p=1955748#1955748#ixzz1V4ZNeavD
Read more: http://www.diynot.com/forums/viewtopic.php?p=2081458#2081458#ixzz1ZXdMEyLA
