- Joined
- 2 Jul 2007
- Messages
- 43
- Reaction score
- 0
- Country
Hello all!
I'm hoping that someone can shed some light in an 'issue' with my boliermate HP DEM??? It is kind of hard to explain, but fairly frequently, the whole thing, including the display seems to freeze, and just continues in whatever mode it is stuck in. If I turn the boilermate on, it will work for a good few hours as it should. But then I check the temperatures on the display and all the numbers seem stuck and it shows a water temperature of, say, 60 deg, but really it has dropped much lower (due to use).
I can turn it off and on again, and it is fine for a few more hours. I can navigate the menu, but all the sensor temps don't change. If one of the pumps was running when it froze, then they keep running, even though the heat pump boiler has stopped producing heat.
Any ideas???
Thanks!
Any ideas???
Thanks!
