Hi All,
I am having an issue with my heating system. Basically, my hot water cylinder in the loft is filling up and overflowing. The water is not coming from the ball valve and instead via an internal route. First assumption was that the coil had gained a hole and the water water was coming in from through the coil. However, I have noticed the sound of water constantly flowing through the cold water supply, I thought this could have been to the header tank that would be supplying the heating system as the water leaked through the coil.......but it isnt.
I started to trace the flow of water, and found it flowing through my mixer shower valve!!!!!
Does anyone know if the valves with the mixer valves of shower can fail and as such the cold water force its was through the system in to the hot water cylinder?? My show is a Bristan Quadrant Shower, with the valve and Taps suck in to the wall.
Hope someone can help
Many thanks
Russ
Many thanks
Russ
