Hi there
bit of an odd one that somebody may be able to help with.
I have a septic tank and noticed that it was filling with liquid quicker than usual. I’ve taken a look and noticed that there is a constant stream of water entering it through one of the inlets. Problem is, I’m not sure where the water is coming from as it is happening when we are not using water. I’ve check the manholes and cannot see water flowing through any of them. I’ve even turned off the water in the road for 60mins to rule out any rogue overflow, but the constant stream continues.
I’ve been checking it when it isn’t raining to rule out rainwater going into the system (I believe the rainwater isn’t connected to the drains going to the tank anyway).
Any ideas why it could be? My only idea at the moment is that there is a crack on the drain run after the manholes and that is allowing water from the recent rain we’ve had to leak into the pipe and then into the tank.
Thanks in advance for any help. Either way, I think I’m going to need a CCTV survey to work out the source of the water.
