I've removed a light fitting from the ceiling in my living room and the connection seems a bit weird.
it has 2 x 1.5mm cables going to it. one of them is the switch and the other one must be the power (can't trace that one back) but shouldn't it have 3 going to it?
also, when I removed the fitting it was connected into a connector block, the live and neutral from the fitting where both connected to a neutral from each of the 1.5mm cables and the 2 lives from the 1.5mm cables weren't connected to anything, they just go into the connector block and then nowhere.
the light was working but is it safe? I don't no much at all about electrics I'm just going off how my other lights are wired up and bits and bobs found on the internet.
