strange lighting circuit connection
7 May 2010
Newcastle upon Tyne
I've removed a light fitting from the ceiling in my living room and the connection seems a bit weird.
it has 2 x 1.5mm cables going to it. one of them is the switch and the other one must be the power (can't trace that one back) but shouldn't it have 3 going to it?
also, when I removed the fitting it was connected into a connector block, the live and neutral from the fitting where both connected to a neutral from each of the 1.5mm cables and the 2 lives from the 1.5mm cables weren't connected to anything, they just go into the connector block and then nowhere.
the light was working but is it safe? I don't no much at all about electrics I'm just going off how my other lights are wired up and bits and bobs found on the internet.
Sounds like it's on the end of the lighting circuit so it only has one feed into it and from what you've written (as weird as it may sound to you) it was wired correctly.
The two lives are the feed & switch connected together the return from the switch (which becomes live when turned on) should be connected to the live on the light fitting. This is normally marked with a sleeve either red on old type wiring or brown on new type then the neutral on the fitting connects to the feed cables neutral to complete the circuit.
It is connected fine but sounds like the red sleeve from the switched live via the black neutral wire has gone awry somewhere along the line. Put some red insulation tape on the black wire that your light fitting live is connected to for future reference for yourself or others looking at the fitting.
