Let me try & explain my problem.....
I've moved into a house that has an unvented heating system - uses a gloworm fuelsaver complheat 55 boiler & a IMI Tribune Premier 180 ltr unvented cylinder + Lifestyle 3 port mid-position valve. All rads (about 16 of them) have TRV's except for two towel rails & donwstairs loo rad.
All of this is run via a Drayton LP 722 programer (seperate HW + CH channels) - also there is a wireless room programable thermostat Honeywell CM927 - the Drayton LP722 programmer Heating side wiring has been isolated & the actions replaced by the programable CM927 thermostat.
Anyways - the problem I have is when the heating is on - all rads get nice & toasty (hot) in all rooms....& seems fine - however when only the (HW) hot water is on & CH is turned off - two radiators in a recently fitted upstairs extension get hot.
In other words there are two rads in the upstairs extension that get hot when HW is on as well as getting hot when the CH is on. No other rads get hot in the house when only the HW is on - why are these two doing so - my suspicions are they have been wrongly plumbed in by the builders of the extension - but without lifting laminate & flooring I am unable to verify.
I woudl welcome your collective thoughts & ideas on this problem please & also what easy/cheap remedies are there to fix it?
Cheers all
Cheers all
