Strengthen metal stud + plasterboard wall
29 Jun 2021
Renovating my en-suite and I wish to add a largish mirror to a wall that will also be tiled. In total though, the weight will slightly exceed the maximum weight for plasterboard i.e. mirror + tiles > 32kg/m sq. As such, i am looking for advice on the best way to strengthen the wall.
I don't yet know the exact size of mirror or its exact location and so I need a slightly flexible solution that will allow me (say) 4-inches of positioning.
Thoughts on options:
1. I can add extra studs by opening-up the wall and I even have a Gypframe Fixing Channel in the garage that would seem perfect for the job. Thing is, i think those channels are normally screwed-in from the front and that will push the PB out by a couple of millimetres!? If so, is there another way of doing it?
2. I suppose another option would be to add a couple of metal studs and somehow attach a piece of plywood between them, but again how is that best done?
3. Just add a couple of extra studs to provide the additional strength required
TIA
ok could be miles out here but tiles and a mirror could never ever be as much as 32kg over a square metre as thats perhaps hanging a person off the wall if its flat face with no great overhang there is next to no leverage so should need no or minimal extra timber just normal support
On a tiler’s forum there was a sticky comment that suggested 8mm tiles plus adhesive and grout would amount to around 22 kg/m². The mirror itself is aroung 13kg.
Having looked at the weight of boxes of tiles that generally amount to one square metres-worth, it seems about right.
you need to remember any large flat structure will spread load and iff well adhered will add to the structure rather than just a dead load so needs a bit off planning as a spread load is is helpful and point load is less helpful
