Looking into buying a house. The house is rendered but from what I can see of the brick work (around 6 courses) it is all stretchers. The house was built in the mid 1920s. I would assume that the construction is an early cavity wall however the vendor has advised it is solid brick wall. I have roughly measured the wall thickness which is around 30cm however there is at least one layer of render on the wall.
Is any one aware of a type of solid brick wall construction that uses stretcher bond?
The road is Wembley Road, Liverpool, L18 if anyone wants to take a look and advise if the think the wall is cavity or none cavity. Most houses on the street are of the same construction.
