Is it usual to prop up brickwork when putting a hole in for padstone and steel end?
The wall is the existing external leaf of a 1970s property, 65mm bricks, 100mm cavity.
the padstone is 440x215 and the room required to get the end of the steel in is about the same, so the hole would be approximately 900mm high and 500mm wide to be safe.
Above the hole is the upper floor elevation and then t he roof gable on top of that.
I’d need to make the hole, lay my courses of blue bricks, let that go off for a few days, then put the steel in, then patch up. So the hole would be open for say five days.
Just wondering what is usual; first timer here. Thanks
