Could be archive storage loading although the beams don't carry any ceiling load so can't be that.Looking at those calcs, where has she got 'ceiling storage 5.0kN/m2' from?
That's about 100 lbs/sq ft, unless I'm missing something.
Seeing the pics, those beams just look so 'wrong'...........![]()
For some reason she has designed for a max span of 8.1m, as opposed to around 5 1/2.
And then she's taken effective length of 1.2...which is conservative if the end of the beam is surrounded by new, well built blockwork.
And then, for some unknown reason she has limited deflection to 6mm.
Despite all this, allowing the deflection to go marginally over 6mm would have meant a pair of 203 UC 46s could have been used.
Are you sure they're not a surveyor?
