Structural plans - councils have a record?
5 Apr 2022
In order to do a renovation on the ground floor and demolish some of the internal walls to create a more "open plan" modern feel to my property I need to identify the load bearing walls of my property and preferably without having to take up the floorboards above
is there a possibility that building control has a record of the property? I'd be grateful to hear your experience. My property was constructed in the 1970s
It is possible that they will have but until you contact them you cannot be sure. Commonsense should enable you to identify whether walls are load bearing e.g. if floorboards run one way the support joists to run the other to load bearing walls, if there is a wall on the 1st floor above one on the ground floor its load bearing, if joists in the loft rest on 1st floor walls its load bearing.
Chances of having plans, just above zero. Chances of having useful plans, just below zero.
You need a competent designer, not 50 year old plans
I’m sure builders never deviate from the drawings……
Extremely unlikely i'd say.
And besides, building control inspections aren't only done by the council, there are also done by independent approved inspectors so you have no way of knowing who would have received/checked any drawings in the first place.
I've never been able to obtain old building control records in the form of detailed plans, just the certificates of completion which are limited to the description of works. Council's say the plans cannot be disclosed under FOI because of copyright, yet it is relatively easy to view and copy planning applications. At the very least the current owner of a property should be able to have access to such drawings.
Blup
Building control only keep drawings etc for 15 years. After that they throw them away.
In 1970? Lol
