Yes - that's the whole point of registration. But do your LABC put obstacles that they should not in the way of non-registered or unqualified people doing it?i have just been reading the local building control and basically for the work i want doing - the council has to be told - but aslong as they chap is registered OK - then he can sign it all off
It's not really a minefield, but LABCs are often unclear - that's what happens when you try to ignore and selectively interpret to your advantage what the regulations say.i have to admit its a mine field of what you can and cant do - and they dont make it very clear
Why on earth do you think that?although it does look like i could rewire the upstairs completly and i have no need to tell anyone
Except in the kitchen, bathroom and outside.5 - then i can add sockets as need be in the future ( if any ) safe in the knowledge that i dont need to notify the council
If you don't then how will it be adequately protected by an MCB sized for 4mm²?out of interest - if its done in a 4mm radial - does that mean that if i add a spur - does that have to be in 4mm wiring aswell ??
Check the specs of the socket - it'll be tight.if thats the case - is it possible to get 3*4mm cables into the back of a socket
