Stuck closed door on Hotpoint WD645a (2005) washer dryer
13 Sep 2005
Kent
The thing has finished it cycle and the "door locked" light goes out - but the door remains firmly shut!
How do I open the door - AFTER unplugging:
- is there some latch inside?
- does pulling a piece of string behind the door work on this model?
I need to open the door to get the serial no. as apparently this is required to get the correct interlock - otherwise, "pumph / bang"
I have taken the top off and probed the interlock but can't find any button / lever / silicon blob mentioned in some forum responses.
(PS - machine still works as have tried partial cycles to bounce the unlock into action but to no avail - but it does goes through cycle selected)
Any help welcome please. Thanks, Mel
There is no blob on that model. As you put you hand on the rear of the lock there is a lever in the lock that goes to the front door trim flick it with a small screwdriver.
Thanks - will try tomorrow when I visit my daughter's house again. Have purchased a new interlock which I am assured is the correct model!
Mel
