    Dismiss Notice
Stuck euro cylinder
Discussion in 'Windows and Doors' started by Hansol, 26 Nov 2014.
  1. Hansol
    Hansol
    26 Nov 2014
    4
    Thanks Received:
    Essex
    Country:
    Hi all
    I'm trying to changer the lock on my front door. I have removed the securing screw on the lock cylinder, but no ,matter how turn the key or thumb turn , it refuses to slide out of the door.
    Has anyone had this problem before and found the solution ??
    Just in case it makes any difference the cylinder is an ERA
  2. Sponsored Links
  3. Meldrew4291
    Meldrew4291
    29 Sep 2014
    18
    Thanks Received:
    2
    Devon
    Country:
    After removing the screw all you need to do now is turn the key until the tab lines up vertically and the cylinder should slide out.
    It often helps to take the handles off, but being a thumb turn this may not be possible with the internal handle.
    Try to at least loosen the handle screws a bit though. This should help.
  4. s60tsy
    s60tsy
    16 Feb 2013
    581
    Thanks Received:
    62
    Manchester
    Country:
    have you undone the right screw? :confused:
  5. Hansol
    Hansol
    26 Nov 2014
    4
    Thanks Received:
    Essex
    Country:
    Definitely the right screw, my back door has the identical lock and the barrel comes pout with no bother
  6. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    500
    Sussex
    Country:
    spray some wd40 type stuff in and around it,as they do tend to gum up with crud.then make sure as said the tab is in line,and then TAP IT VERY GENTLY hopefully it should then slide out.
  7. KenGMac
    KenGMac
    24 Aug 2010
    3,559
    Thanks Received:
    678
    Ayrshire
    Country:
    If you live near the Sea, then corrosion may be the culprit ?
    WD40!
  8. Sponsored Links
  9. Hansol
    Hansol
    26 Nov 2014
    4
    Thanks Received:
    Essex
    Country:
    it not corrosion. The cylinder will move in the lock. It feels as if the cam isn't lined up, but after slowly turning a full 360 countless time, there must be another reason why it won't slide out
  10. ronniecabers
    ronniecabers
    14 Nov 2014
    808
    Thanks Received:
    150
    Country:
    Silly question, was the barrel actually locking the door before? If not the pins may be engaging and key/thumbturn spinning but not engaging the cam, hence it won't release.
  11. Hansol
    Hansol
    26 Nov 2014
    4
    Thanks Received:
    Essex
    Country:
    The lock is working fine, just want to change the lock after loosing a set of keys
  12. Johnmelad
    Johnmelad
    22 Mar 2007
    1,142
    Thanks Received:
    103
    Cumbria
    Country:
    Take handles off as stated above. You only need to turn the key slightly and tap a bit harder as you wiggle the key.
  13. ronniecabers
    ronniecabers
    14 Nov 2014
    808
    Thanks Received:
    150
    Country:
    Yep , agree with John, take the handles off as has been suggested ( you may not get the one the side of the thumbturn off though... ) . Even with a tap , if it still doesn't come out , at least you will be able to see the barrel actually sitting in the lock , and you may be able to work out why its not coming out.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
