Stud wall insulation
17 Nov 2005
Manchester
following on from my post in the electrics forum.
What is the best insulation to use in a loft stud wall that has been built in front of either party wall please?
Thanks.
Hello thanks for your reply,
Primarily for heat according to the LBC but I also want some degree of sound insulation with it.
Thanks.
The best in what terms? Looking, cost, easy to work with?
You are aiming for a certain u-value, and any insulation will achieve this in varying thicknesses.
It depends on what your criteria are - more cost thinner insulaltion, less cost thicker insulation.
Dense (ie Rockwool) is good for sound, as is using thicker or specialist plasterboard
my stud work is 3 by 2 so i have a 3inch gap to play with (oh ar missus)
but I need to leave a gap for wires etc so max 2inch thick
Dont want to spend a fortune and im only a diyer so it needs to be easy to work with I could do with not having to secure it in, can the boards be cut then squeezed in without fixing?
