Stud work and pocket door help please
23 Dec 2014
Aberdeen
Hi all,
I want to partition a room with stud and install a pocket door into the the stud wall. I am clear on everything other than the size of the timber for the stud I should be using.
The pocket door system I'm looking at specifies the pocket door frame needs to be attached to either 75mm or 100mm stud. The timber I was looking at was 75mmx50mm CLS the actual size of which is smaller at 63mmx38mm.
Question is would the cls be ok to use or should I source timber at the actual 75mm.
Many Thanks
