I strongly we are likely, if not already, be running around a hamster reel with this discussion.
Electrically I think you are in a most ways correct that it is hard to justify the need for another piece of protective equipment - in fact in some ways it could be detrimental.
However for a number of non-electrical reasons there is seen to be a benefit in installing the device. For these reasons the ESI decided over 30 plus years ago that the length of tails (face it an unprotected submain is in effect a set of tails) without addition fuse protection should be 3m.
The point of supply being the meter outgoing terminals is the starting point.
This physical point also marks the changeover from the Supply Industry to the IEE regulations which may also have some relevance to the discussion.
In the real world, as we know, life is not that simple, this whole argument being negated in some ways by the huge amount of supply cables (both armoured and not) that run through properties with their only protection being the fuse at the local substation.
