Subsidence cracks getting longer by the day
Ive got one booked for 3 weeks time.
These cracks are getting wider and longer by the day, and new ones appearing.
But these cracks are only going to get worse.
Are they? A little anecdote that relates to @stevie888 post above.
Many years ago a friend of our family bought a huge house on a hillside sloping down to a river estuary. It was really cheap because it had "severe subsidence", and was being sold as such. My stepfather was an arborist and horticulturist, and the plot this house stood on was bordered by a row of poplar trees all down one side. Stepfather said "cut down the trees", which they did. The house came back up, all the cracks closed and no underpinning was ever done. AFAIK it has been OK ever since. Poplars apparently are one of the worst trees for sucking water out of clay soil.....
This has happened over the past few days!
All others are getting wider/longer. These are appearing all around the house, and on the internal walls downstairs. This is not one r two localised subsidence issues, tis is affecting the whole house!
Take photos of all walls and cracks now, then compare in a couple of weeks and post before and afters. And post up a diagram of where the cracks are on the house. Otherwise it's difficult to see what's what.
This summer broke records!
That's my guess too - lots of drying out then fairly fast re-wet and the ground has just moved a little. If it's a cob house with hard plaster (not lime) it's quite likely going to get a bit of differential movement.
I got the SE's report back. He said the cracking is due to gypsum plaster having been used, and roof spread. But theres a lot of caveats about not being certain its not subsidence.
The external render is blown, and moisture is getting in but being blocked due to the gypsum plaster.
I dont have the money to spend on rerendering the house, replastering, new roof etc. I dont know what to do.
Roof spread can be rectified yourself if you do some research. I have seen it done. Find a decent builder via word of mouth who can look at it all and come up with a plan.
I don't know much about cob walls, but I do know a bit about condensation, evaporation, humidity etc., so I did a bit of reading and this sentence stood out on a specialist cob wall page "Once the moisture level exceeds 12% the strength of the cob drops dramatically." https://mikewye.co.uk/knowledge/how-to-guides/cob-repair/
If you have a situation where you have leaking render, and no mechanism for the moisture to evaporate in to the internal warm room (because of the gypsum plaster), then perhaps the roof spread is purely because the cob is starting to lose its structural integrity.
I would speak to a specialist cob wall person.
