Suction
10 Sep 2004
Here is the problem.
Four walls of various materials (bonding, sand & cement and painted plaster) due to years of repairs. I am going to skim over as the walls are sound and do not really warrant overboarding. I was planning to PVA the walls to get uniform suction but was not sure exactly what mix to use or how many coats.
I was going to give each wall a coat of 70/30 Water / PVA and allow to dry then a second similar coat just prior to skimming as I was told by a plasterer to make sure that the wall is tacky before it is plastered.
Is this the correct method or would I be better with a different approach?
Any help would be most appreciated.
you could use bond it instead of pva its more expensive but will give you a more universal suction to the walls :wink:
Many thanks again Jbonding for your help.
I have not used bond-it so was not aware of it. Is it a specific plaster pre-treatment?
