can anyone suggestion best way to wire this philips light in and tidy up existing wiring on ceiling light. I was thinking of wago connectors as need to push all wiring back in the ceiling as it won't fit in this new philips spray spotlight. Thanks
Rewire using proper JB, new luminaire large enough to cut hole in ceiling big enough to push one of these up into the void (58mm) , bring 3 core flex out into new fitting.
Hello. I realise I have 4 wires going in to the loop. Also does the box need to be MF? I have almost no extra give in the cables so looking for the simplest modification and suggestion of a small junction box I can create hole in ceiling and poke through. Thanks
My first tip is to make sure you can identify the black wire sleeved red which is called the switched line, it has the red sleeve but in addition its worth adding some paint or marker pen to the wire or the white sheath in case the sleeve gets pulled off.
When you take the ceiling rose off you should be able to look up into the hole and possibly see the cables are clipped to the joist, sometimes it's possible to very carefully use a screwdriver to prise those out and gain a small amount of slack, it will also assist with being able to push the junction box into the ceiling void.
It only needs to be MF if it's not accessible, so if it can be pulled back through the hole with the light removed it doesn't have to be MF but it does have to have secure cable clamping arrangements as the suggested box does.
Have you tried pulling down a bit on the cables once the rose is unscrewed from the ceiling ? There is usually some slack on the wiring to give you some extra length.
Thats the plan for tomorrow. Didn't seem to be any when the rose was on. I have 4 wires going in to the loop (not 3) so will wago these with a box but only if I have the slack to get it all in there. Also have the idea 30-4000 box to use. Plan is wago or ideal 3x5 lever plus 1x2 lever.
